Air Suspension Help
1 reading
3.8K views 34 replies 14 participants last post by  Just1n
#1 ·
Bags/Struts:
(2) RE-5 Slam Specialty
(2) Easy Street Air Struts
Compressor:
Air Zenith
Tanks:
(2) 2 Gallon Tanks (Height- 8" with feet, Length- 17" port to port.)
(1) 5 Gallon Chrome Tank (Length- 25", Height- 9.5" with legs, 8.25" diameter)
Valves:
(8) SMC 3/8”s
Switches/Gauges:
Dakota Digital Ride Height Controller (DHC-202)
(8) Dakota Digital Sending Units
Lines/Fittings:
1/4” DOT Air Line
I dont know which fittings I need or which Tank I can fit underneath the car- I was looking @ the Air Runner, Easy Street, Suicide Doors, FBI websites when i created the list above- dont know what i need besides fittings and and something else....dont know what size fittings and what exactly i need SOME HELP ME OUT
Save
#5 ·
Im looking at the end of the month
And you didn't call me why? We'll talk about this tomorrow when you come by for the body kit. :cool:
Cuz I knew Id see you tomorrow
hey dont buy the easy street stuff its crap listen to taz he has a good set up. If you want a good kit pm me I just emailed FLOSS a bitchen set of stuff to do his for a hell of alot cheaper than you can find a kit for.
and taz just curious if you dont mind me asking how much did you pay for you set up. if you want just pm it to me thanks
The ES Strut wasnt bad- but any suggestions are much apppreciated :)
Save
#4 ·
#6 ·
I have heard that the easystreet struts go bad and begin to clunk until warm.....
Our tank will probably not be ready until end of August or September
I can try to hurry it up a little, let me know how many ports do you need, would you want a tank drain valve and will you be mounting all of your valves under the car or inside?
Show me a photo of the tank you are looking at running inside the car and I will see what I can come up with.
#13 ·
air zenith is a good comp. but they are $300 and the viair 380c's combo come with 2 and a pressure switch and two relays for $290. think about it. that setup up there is almost the same way I am going to do mine but my tank is going to be smaller in size but still 5 gallon just the same as the link I sent you.
#15 · (Edited)
Only reason I was thinking Air zenith- is I want to send a proposal to them and try to get sponsored for that compressor and switch. If not the Viair is what ill go too-
Stainless air lines ? Where can i get those ?
hmmm..interesting....
air would be nice....
these guys know their ish Chris....
you are in good hands!!
Oh i know they do !!!
Im stoked im getting this help I dont want another bullshit expience on the freeway
Dan- what you think about this:
http://www.viaircorp.com/20005.html
Save
#18 ·
Defiantly- if I dont hear back Im going to go with Viar and see what they are looking at with sponsorships.
Save
#25 ·
i couldn't figure out how to mount mine under the rear. you definately need to fab up some kind of rack like you see in the pics. i've just got mine mounted in the rear cargo area for now. the chrome tank and chrome compressors look to pretty to hide under the car IMO. :eek:
#29 ·
I hear a lot of bad things about easystreet. Are there any completely put together kits for sale on the market that are a good buy? or is the only way to get air ride for an xB these days to buy all the piece you need individually?
#34 · (Edited)
I decided to piece a kit together..
I'm leaving some of the smaller stuff out, but here's the basic run down.
Front struts from FBIrides.com - Easy street air lift - $550
Rear Bags- RS52 slam specialties - 75$ ea
Rear bag brackets from fbirides - $85 ( I might go billet from randode - $200)
Compressor - Viair 450 - $210 Shipped from candospecialties.com
Tank - 5 gallon 8 port - $55 from gaugemag
145 pressure switch - $15 from gaugemag
water seperator - $23 from gaugemag
9 switch plexi switchbox - $20
Lots of DOT brass fittings - ~$60 fom suicidedoors
50 ft 3/8" tube - $20 gaugemag
50 ft 1/8" tube - $8 gaugemag
(2) Easystreet dual needle gauges 0-200psi -$29ea ($58 total)
(8) SMC Valves, 10mm orfice, 3/8" ports w/ brackets- $48 ea ($384 total)
Total is somewhere around $1600.00
Maybe more if I need $200 for Cusco camber plates
Edit: If you feel like helping me out I have a few questions, I posted here:
http://www.clubxb.com/forums/f26/11634-air-ride-s-camber-s/
or
http://www.scikotics.com/forums/showthread.php?t=11924
or here
http://www.scionlife.com/forums/viewtopic.php?t=184563
Any pics of the compressor/tank UNDER the bumper??
You have insufficient privileges to reply here.
